Plot Actual Size
Plot Actual Size
I want to print a 1/2" grid at actual size, to use as a template for sketching the outline of wood toys. I don't see anything for scaling drawings when you print.
Re: Plot Actual Size
After launching the print preview an option bar pops up at the top of modelspace. It has a scale option ...
Note: Qcad application grid isn't scalable / printable. You need to design your own grid ..
It is common in CAD to NOT draw at scale, choose a drawing unit and draw everything in scale 1:1 in that unit.
This avoids scaling every value forth and back between real world and the digital version in Model_Space.
How this is presented on paper in a later stage depends on the paper scale for printing.
For example to fit whole your drawing on a limited size of paper.
Here the advice is to draw a grid on a drawing in inch, stepped a half inch and then print that in scale 1:1.
Mostly rather accurate but depending your printer that might be slightly off.
See Application .. Preferences .. Printer Settings .. Calibration.
Re: Plot Actual Size (solved)
Thanks for the responses, this should work. I always draw in 1:1. As far as accuracy of the printer, it's not critical. I just want to be able to draw freehand on a grid and then cut it out as a template, rather than manually drawing the grid every time. I can simply glue the paper to cardboard.
