Wierd Printing
Wierd Printing
When I select Print Preview all my construction
lines go away and the grid stays. I he select print
preview and te lines come back. any clues as to what
is going on?
Wayn
is going on?
Wayn
Re: Wierd Printing
could you please attach the drawing to this posting? If confident please feel free to use my PM. Thanks.
Re: Wierd Printing
Hi Husky,
I would be glad to attach the drawing, but
I always have a problem with that. A few
instruction on how to do that would be helpful
or point me to the doc that tells how. Would you
like a before and after drawing before I select
print preview? Thanks for the help.
Wayne
Wayne
Re: Wierd Printing
Check this out:wayne67 wrote:Hi Husky,
Wayne
viewtopic.php?f=47&t=3760
And yes, every information what helps to understand the problem would help.
Re: Wierd Printing
Here are the files before selecting print,
then after selecting print and if I do a zoom
what te screen looks like.
- Floor-Plan-After.dxf
- (99.95 KiB) Downloaded 558 times
Re: Wierd Printing
I hope you got them all. there should be 3 file.
1 before i select print, 1 after i select print and
1 that sows the the effect of zooming.
OS is linuxmint, current version of Qcad on
a 64 bit machine.
a 64 bit machine.
Re: Wierd Printing
Hi Husky,
I change some print parameters and that seem
to stop the construction lines from becoming
invisible. Can you tell me how the x and y offset works
for setting print parameters?
Wayne
Wayne
Re: Wierd Printing
Hi Waye - thanks for the test dxf,
The Lines are not disappeared - there are only extremely tiny because of your settings and you are now in an extreme zoom. Check it out: Load the drawing - click the Print Preview and you will see ONLY the grid (what you told us). Now use the zoom and zoom out and out and out until you are able to see the whole page. Now compare the size of your drawing to the page size ...
Here are your drawing settings:
Your Drawing unit is: Foot - OK!
The drawing has a rectangle of 76 foot by 30 foot - OK,
The settings for the Page size is customized: 11 foot by 17 foot. You must have a big printer, haven't you
And your scale for the printing is 1/4096" = 1'-0" - not OK.
I don't know the size of your printer but if I keep the settings for the drawing unit (Foot) and choose an ANSI A Letter as the page size your scale for printing should be around 1"=128"
And for the Viewport Offset x,y - click the Button for Zero Point.
Try it and tell me please how it works for you.
The Print preview isn't working weird - it is just doing what you told QCAD.wayne67 wrote:When I select Print Preview all my construction
Re: Wierd Printing
Thanks again. I will try your suggestion.
Some day I am going to understand this scaling stuff.
I hope somebody writes a book on QCAD that goes
into great details.
Wayne
into great details.
Wayne
