Missing fonts
Missing fonts
Postby dpawson » Wed Feb 11, 2009 7:53 pm
How can I find out if a font contains a specific character please?
Looking for u0x5C, backslash. Seems not to exist in any of the fonts
available?
DaveP
dpawson
Postby andrew » Thu Feb 12, 2009 12:56 pm
The backslash should certainly exist in most fonts (standard, courier, coursive, unicode, ...).
The font files are plain text and easy to understand. You can also load font files with QCAD to import the glyphs as blocks. This way you can add new glyphs to a font or change existing glyphs.
Postby dpawson » Thu Feb 12, 2009 1:32 pm
andrew wrote:The backslash should certainly exist in most fonts (standard, courier, coursive, unicode, ...).
Using the modify text idea, I tried every single font available.
None provided a visible glyph for backslash. ""
DaveP
dpawson
Postby dpawson » Fri Feb 13, 2009 2:17 pm
Also missing:
{ } Left and right curly brace
backslash, as noted.
The 'star' (shift 8) is transformed into a cross.
Not nice, when the app is boasting about Unicode support
dpawson
Postby dpawson » Sat Feb 14, 2009 9:21 am
Do you have any reference for the markup please Andrew?
"Easy to understand" .... when you know how?
Dave
dpawson
Postby andrew » Sat Feb 14, 2009 11:32 am
"Easy to understand" as in you can probably figure out what glyphs they contain. Each block defines the glyph for a character and the character is present in the font file in plain text. For a capital A of the standard font:
[0041] A
... glyph definition ...
You do not want to edit these files manually. Load them with QCAD and use QCAD to view / edit and add glyphs as blocks.
Note that the backslash is not working because it is used for special escape sequences for superscripts and subscripts (see manual). This will be fixed with a workaround (most likely \\ for one backslash) in future versions.
Postby dpawson » Sat Feb 14, 2009 12:00 pm
andrew wrote:"Easy to understand" as in you can probably figure out what glyphs they contain. Each block defines the glyph for a character and the character is present in the font file in plain text. For a capital A of the standard font:
[0041] A
No information on glyph definition?
How might I 'load them with QCAD, or edit them as blocks?
Nothing found in the documentation.
dpawson
Postby andrew » Sat Feb 14, 2009 12:08 pm
In a nutshell:
1. File - Open - choose "Font *.cxf) as file format
2. Make sure the block list is shown.
3. Edit blocks / add blocks to edit / add glyphs.
Format of block names:
[xxxx] A
Where 'xxxx' is the hexadecimal Unicode of the glyph and 'A' is the glyph itself (optional).
Basic knowledge on working with blocks and Unicode is required.
Postby dpawson » Sun Feb 15, 2009 8:35 am
andrew wrote:In a nutshell:
[xxxx] A
Which isn't much good when the application doesn't follow those rules?
the 3 examples I quoted are correct according to your definition
and Unicode v5, yet don't show correctly.
Thanks Andrew. I'll wait for the next release.
dpawson
Return to Chat
cron
