Precision Preview dimensioning ...
Post by Husky » Sat May 10, 2014 10:52 pm
QCAD 3.5.0
I'm just wondering - is this new or I just did not notice that before?
My settings for Dimension are mm / decimal / precision 0.00
If I do my dimensioning the preview of the dimensioning has a precision of .0000 but the finished dimension shows me my desired .00. Is this on purpose? I can't remember that this has worked in the past on that way .... maybe just me. :oops:
Edit:
How do I get the same Preview Size to be able to place my dimension correctly?
This test is done with the settings: mm / text hight 25 / decimal / precision 0.00
Edit: And if I use tools like move, copy, rotate etc the preview has a different size and precision?
Move/Copy tool
Re: Precision Preview dimensioning ...
Post by andrew » Mon May 12, 2014 9:26 am
Post by andrew » Mon May 12, 2014 3:19 pm
A bug fix release 3.5.1 is now available in your download area.
Post by Husky » Mon May 12, 2014 8:28 pm
andrew wrote:A bug fix release 3.5.1 is now available in your download area.
Works great! Thank you.
Post by andrew » Mon May 12, 2014 9:22 pm
OK, thanks for letting me know!
