Hello, I was looking for an inexpensive CAM program when I came accross your products. I downloaded both QCad and CAM Expert demos. I like the ease of operation, reminded my of the JetCAM system.
Question 1) Will Cam Expert be updated and when will it happen?
Question 2) Can it be used to create gcode for a Turret Punch Press?
Question 3) For Laser operation, I had difficulties to force a particular cutting sequence. Is it actually possible to select the sequence manually?
Question 4) Are there any machine setup files for Fanuc 6m controllers available?
Thank you, Tom
