build qcad for XP. But it fail. I Install mingw, msys and qt open
source from trolltech v.4.4.0.
I start msys and
export QMAKEPATH=c:/Qt/4.4.0
export QMAKESPEC=win32-g++
export QTDIR=c:/Qt/4.4.0
sh build_qcad.sh
- Code: Select all
MinGW32-make[3]: *** [obj/rs_actioninterface.o] Error 1
MinGW32-make[3]: Leaving directory `C:/msys/1.0/home/Dirk/qcad-2.0.5.0-1-community.src/qcadlib/src'
MinGW32-make[2]: *** [release] Error 2 MinGW32-make[2]: Leaving directory `C:/msys/1.0/home/Dirk/qcad-2.0.5.0-1-community.src/qcadlib/src'
MinGW32-make[1]: *** [lib/libqcad.a] Error 2 MinGW32-make[1]: Leaving directory `C:/msys/1.0/home/Dirk/qcad-2.0.5.0-1-community.src/qcadlib'
MinGW32-make: *** [all] Error 2
Building qcadlib failed
Then in the output there is this
In file included from actions/rs_actioninterface.cpp:28:
actions/rs_actioninterface.h:31:21: qobject.h: No such file or directory
actions/rs_actioninterface.h:32:21: qaction.h: No such file or directory
- Code: Select all
In file included from ../include/rs_entity.h:33,
from ../include/rs_atomicentity.h:31,
from ../include/rs_arc.h:30,
from ../include/rs_entitycontainer.h:31,
from actions/rs_actioninterface.h:34,
../include/rs_dict.h:31:19: qdict.h: No such file or directory
qdict.h, qobject.h are not at my system. I found out that it is from
qt3. But qt3 is not available. I found qt3 to build out of source but I
can not build. I install cyqwin with qt3. now I have all the files at
my system. But how can I use them?
Dirk
