I have a dxf file with some layers, and in one of these layers there are several blocks. I need to extract the coordinates of the points which define each block. Is there any way to obtain that? It would be valid even a command giving the list of the points, so that I can copy and paste it...
I have never used any CAD program, so I do not have too much idea (if you could explain the procedure in a easy way).
Thank you in advance!!
