Chamfering or Rounding corners of hatched entities
Postby silvic » Thu Jan 08, 2009 5:48 pm
I use QCAD 2.2.2.0 both on Windows Xp and on Ubuntu 8.10.When I try to chamfer or round the edge of a filled object (hatch),it doesn't work,Qcad draws the new line (or curve for rounding) but doesn't delete the content of the hatch which is outside the new shape.
Well,as a workaround you can first chamfer the edges of the object then fill it,but it would be nice to be able to do the opposite.
Thanks in advance for any ideas
Silvano
silvic
