Dim accumulated an axis
Postby ggsalas » Sat Jan 17, 2009 3:12 pm
How do the dim of rethinking plane? = Dim accumulated an axis
Image example of the dim that I need:
ggsalas
Postby andrew » Sat Jan 17, 2009 5:16 pm
Ordinate dimensions might be what you are looking for.
Postby ggsalas » Sun Jan 18, 2009 2:14 am
andrew wrote:Ordinate dimensions might be what you are looking for.
Ordinate dimensions measuring from 0.0, I need from a variable. Besides the ordinate dimensions have no arrow.
Is simpler, it's a dim that only has an arrow and the text is aligned to one side.
Thank you.
ggsalas
Postby andrew » Sun Jan 18, 2009 10:16 am
ggsalas wrote:Ordinate dimensions measuring from 0.0
You can move the reference point of ordinate dimensions:
- select ordinate dimension(s)
- move blue reference point at absolute position (0,0) to desired relative zero point
Dimension entities that look exactly as shown in your figure are not supported by QCAD.
Postby apjjr » Mon Jan 19, 2009 1:09 am
Is there a way to set the ordinate 0,0 to a relative location before drawing dimensions so we don't have to move it after drawing the dimensions?
-Alex
apjjr
Postby ggsalas » Mon Jan 26, 2009 7:44 pm
I need not be identical to the image, but the levels I tried were really bad. Is there a way to customize your appearance?
Thank you
ggsalas
Postby andrew » Tue Jan 27, 2009 10:44 am
ggsalas wrote: Is there a way to customize your appearance?
No, sorry.
One possible solution
Postby ggsalas » Mon Feb 09, 2009 4:55 pm
I want to know whether it is possible to place a text that shows the value of the coordinate (in x).
If this is possible, Drawing a block to the levels accumulated in x and one for the levels accumulated in y
http://picasaweb.google.com/lh/photo/gTy7PHUzuzg2sbgwyrbvoA?authkey=FwtBimo82vw&feat=embedwebsite
Maybe you can use scripts?
ggsalas
Re: Dim accumulated an axis
Postby ggsalas » Wed Jul 25, 2012 5:56 pm
With blocks and/or scripts this can be possible?
ggsalas
Postby andrew » Wed Jul 25, 2012 6:10 pm
With a QCAD 3 script, this is certainly possible.
Have a look at the example script in scripts/Examples/DrawExamples/ExThreePoints
This script lets the user click a position and then adds three points beside each other at the chosen position.
Instead of adding points, you can add any other entity type, including text labels.
