Crashes when saving
Crashes when saving
Postby anrol » Wed Oct 08, 2008 8:08 pm
I just downloaded QCad this morning, and do not seem to be able to save a drawing. Every time whether choosing "save" or "save as", the program crashes and closes.
Any ideas?
Thanks,
Lorna
anrol
Crashes when saving
Postby cadstevens » Thu Feb 05, 2009 10:29 pm
I use QCAD 2.2.2.0 and I have the same problem.
When I save a new drawing the program crashes.
When I open an existing drawing an save the changes on a local drive there is no problem.
What can I do to fix this problem?
I look for your response.
Yours faithfully,
Matthias
cadstevens
Re: Crashes when saving
Postby anrol » Thu Feb 05, 2009 11:02 pm
I uninstalled/reinstalled the printer from my computer, and everything seems to work now.
anrol
Crashes when saving
Postby cadstevens » Tue Feb 10, 2009 12:00 pm
I'm sorry, but the printer installation didn't fix the problem.
Are there any other ideas?
Thanks,
Matthias
cadstevens
Postby andrew » Tue Feb 10, 2009 2:08 pm
Please indicate operating system, operating system version and QCAD version in every problem report. Thanks.
Crashes when saving
Postby cadstevens » Tue Feb 17, 2009 10:09 am
I use QCad 2.2.2.0. I used Windows XP Professional and now Windows VISTA Business Edition.
When I use the version 2.2.1.0 there is no problem.
Thanks,
Matthias
cadstevens
Postby Uchida » Tue Feb 17, 2009 12:52 pm
I posted same problem, though I didn't get any comments on my post at last. :cry:
Anyway, when I reset my QCAD by removing QCAD.ini it solved my problem and now it works fine for me.
Worth trying.
http://www.ribbonsoft.com/qcad_doc_faq.html#7
Uchida
Mac OS X 10.5.6m 1.83Ghz/2GB, QCAD2.2.2
Uchida
Postby Uchida » Tue Feb 17, 2009 1:04 pm
Hello again,
I thought resetting had solved my problem but it was only accessing local files.
When I tried to open a file in a network drive (Samba sharing point). It went to crash. (Mouse cursor rotating forever).
What a shame.
It was OK when I was using version 2.2.0.
Uchida
Uchida
