introduce script variable content in command line
dfriasb
Senior Member
Post by dfriasb » Sat Mar 31, 2018 1:01 pm
Hello all,
I would like to write a script that works like this:
1.- Ask me in command line to introduce a string.
2.- Use this string to find certain layer names.
3.- Set specific properties to this layers, like freezing, locking, etc.
I know how to do steps 2. and 3., but I never succeed on step 1. I've found the way to ask a coordinate via command line, but not a string to fill a variable content of the script. Any help with that would be appreciated.
Regards! David
David Frías Barranco | architect
[email protected] | davidfriasarquitecto.es
dfriasb
Senior Member
Re: introduce script variable content in command line
Post by dfriasb » Tue Apr 03, 2018 2:43 pm
Here I attach the script. It is working, but just for one specific string: ".v1"
isolate.js
(1.68 KiB) Downloaded 860 times
I would like to be able to define the variable
subs
that contains this string, from QCAD.
Thanks,
David
Post by andrew » Mon Apr 09, 2018 9:34 pm
Actions in QCAD are event based. Whenever something occurs (mouse moved, mouse clicked, key pressed, command entered in command line, action begins, action ends, etc.) an event is triggered.
If you want to stop everything and wait for the user to enter something, you need to show a dialog.
The command line can be used at any time while the action is running. If the user enters a value, that value is passed to commandEvent of the action:
MyAction.prototype.commandEvent = function(event) {
    var cmd = event.getCommand();
    // user entered the contents of cmd in command line
