I have a doubt about using the list of blocks.
Postby ggsalas » Mon Feb 23, 2009 3:27 pm
Hello. I have a doubt about using the list of blocks.
When editing a block the block list is empty. This happens even if the block containing blocks.
The only problem is the list of blocks: Switching off a block in the original design, it turns off in the block that I am editing.
Greetings.
ggsalas
Postby andrew » Mon Feb 23, 2009 4:14 pm
Nested blocks are currently not supported by QCAD.
Postby ggsalas » Mon Feb 23, 2009 4:23 pm
andrew wrote:Nested blocks are currently not supported by QCAD.
In fact if it works. What is annoying to see the list of blocks I go to original drawing.
I hope this will be solved soon.
Thank you.
ggsalas
Postby ggsalas » Tue Oct 20, 2009 4:19 am
When will there be support?
With this tool could divide my architecture project in blocks (drawings [1]) and sub-blocks (objects).
All the objects could manage with layers (for levels [2])
[1] Example: architectural plan, plumbing plan, etc.
[2] Example: 1º Floor plan, 2º floor plan, etc.
ggsalas
