I created a dimension using "yellow" instead of "of layer".
Then I liked to change the colour of the dimension. This is unfortunately impossible (neither for the labels nor the dimension lines). Then I created a new one using "of Layer" and tried to change to any colour: again not possible.
For lines the same procedure works fine, but not for dimensions.
Is there a simple solution or is it a bug?
Best regards,
beta-L-user
