QCAD 2.1.3.2 quits when help is selected
Postby apjjr » Sat Jun 02, 2007 5:36 pm
Selecting help from the menu or pressing F1 makes QCAD quit.
I just installed QCAD 2.1.3.2 on an up-to-date Ubuntu 7.04 as follows:
cd /opt
sudo tar xzvf ~/qcad-2.1.3.2-1-prof.linux.x86.tar.gz
sudo rm -r qcad-2.1.2.8-1-prof.linux.x86
sudo rm -r qcad-2.1.3.0-1-prof.linux.x86
cd /usr/bin
sudo ln -s /opt/qcad-2.1.3.2-1-prof.linux.x86/qcad qcad
If started by directly referencing the path rather than the link, I get the following error in the help window:
The page could not be found
'/opt/qcad-2.1.2.8-1-prof.linux.x86/doc/index.html'
I linked the qcad-2.1.3.2-1-prof.linux.x86 directory to qcad-2.1.2.8-1-prof.linux.x86 in /opt and by starting QCAD with the full path reference, now help works.
Is there a way to clean this up? Have I done something wrong in the install?
Alex
apjjr
Postby apjjr » Sat Jun 02, 2007 7:15 pm
I finally figured it out!
When QT Assistant is run, it looks in your HOME directory for a dir named .assistant. If found it uses it. If not, it creates it.
The contents of my old .assistant directory as follows:
contentdb40.QCad indexdb40.dict.QCad indexdb40.QCad
contentdb.QCadManual indexdb40.doc.QCad indexdb.QCadManual
These files referenced the old 2.1.2.8 installation.
Deleting the .assistant dir and restarting qcad from the install dir fixed the problem.
I changed the link I originally created to a script with the following lines:
# start qcad from install directory
cd /opt/qcad-2.1.3.2-1-prof.linux.x86
exec ./qcad
Is QT Assistant supposed to update these references by comparing the current version with the referenced one or some other means?
Alex
apjjr
