I have posted this before in another thread ("Printing to pdf/ps comes out blank") in October '09 and have not received a response yet.
System: 32-bit
OS: Ubuntu 8.04
RAM: 500MB
QCAD Version: 2.2.2.0
[Professional]
Date: Aug 28 2008
Modules: Scripting
Qt Version: 4.4.1
With nothing in my drawing except a simple rectangle, or any other simple element (to remove the doubt of memory issues), I cannot export to PDF if I set my paper format to be Custom (18"x24"). Print Preview shows the drawing perfectly well, but the PDF generated is blank.
If I use B2 size from the predefined list instead of choosing Custom, then the same drawing generates correctly in PDF. B2 size is 19.7" x 27.8".
This creates a big hassle at the print shop trying to explain that I actually want 18"x24" instead of what the PDF shows, i.e. 19.7"x27.8".
Please help. Thank you.
