Numbers I enter on the Command Line do not show up once the command is executed.
For example I enter @0,0 in the Command Line for the start of a two point line and press enter. The line starts correctly at the relative reference but @0,0 does not show in the Command Line history. Then I enter the end point via the Comman Line and again those numbers do not apprear in the Command Line history.
Any help would be appreicated. Thanks.
Bruce
Win7, Qcad 2.2
