An easier way to modify entities (rectangles)
Postby Jesusfreak » Fri Jun 15, 2007 11:21 pm
when I draw a rectangle and try to modify its properties afterwards I have to modify every single line of it. Doing so is pretty time consuming. I would suggest to change this in a way the user only has to change the two points diagonal to each other.
Regards
Jens
Jesusfreak
Postby webrider » Sun Jun 17, 2007 4:19 am
You didn't specify if you want to change line properties or the rectangle dimensions. The Edit>Stretch Entities tool may be worth looking into, as a solution to changing the rectangle dimensions.
webrider
Postby Jesusfreak » Tue Jun 19, 2007 2:58 pm
webrider wrote:You didn't specify if you want to change line properties or the rectangle dimensions. The Edit>Stretch Entities tool may be worth looking into, as a solution to changing the rectangle dimensions.
I tried it the way you described and it worked.
Jesus
Jesusfreak
Users browsing this forum: Yahoo [Bot] and 0 guests
