I'm a newbie to splendid Qcad and have currently an issue of aligning objects.
I have an object (couple lines + circles), which is tilted some degrees and would need to rotate it to have its main axis strictly vertical. The problem is the rotate tool only accepts degrees as input and I dont know those degrees. Is there a way to specify the rotation via a reference point + target point like with other tools.
Thanks for the great software !
Kari
