"invisible" sub-layering
klavs
Postby klavs » Sat Dec 04, 2010 6:27 am
If I create a layer - with my own drawn blocks - and then create a new layer, and move two of the blocks (using attributes layer change) to the new layer.
The two objects disappear, when I hide the new layer. But if I unhide the new layer - and hide the original layer - they also disappear, with the rest of the objects :(
It seems the new layer has become a sub-layer of the original.
How do I avoid this?
p.s. If I mark a new layer, and redraw the blocks lines (using 2point lines) - the new item is on the new layer AND isn't removed when I hide the original layer (probably because it never had an original layer - it's new line-entities).
So it's when change attributes of a block-element this happens. Changing attributes on line-entities works fine.
klavs
This is using v2.2.2.0
Postby andrew » Sat Dec 04, 2010 10:08 am
Please keep in mind:
Each block insert is on a layer.
Each entity (line, arc, ...) inside a block definition is also on a layer.
klavs
Postby klavs » Sat Dec 04, 2010 10:29 am
So basicly - I can't draw something on layer 1 - create a block from it - and copy this - and use the copy on another layer (where layer 1 is hidden)?
Postby andrew » Sat Dec 04, 2010 10:32 am
In this situation, you would create another layer (e.g. "block_contents") that contains the entities inside your block definition and is independent of layer 1 or the other layer.
Return to “QCAD 2.1/2.2 Troubleshooting and Problems”
