How to draw text with the dxf->writeText()
Postby Oleg » Thu Jan 13, 2011 3:04 pm
Hello!
I have a question. How to use dxf->writeText(...)
In *.dxf file I draw only one text string with dxf->writeText()
AutoCad (2000, 2002, 2004, 2005) error:
AutoCad 2005
The following error was encountered while reading
in TEXT starting at line 1518:
Unexpected DXF group code: 73
Invalid or incomplete DXF input -- drawing discarded.
my code:
DL_Codes::version exportVersion = DL_Codes::AC1015;
dxf->writeText(
      *dw,
      DL_TextData(
      0.0,//X Coordinate of insertion point
      0.0,//Y Coordinate of insertion point.
      0.0,//Z Coordinate of insertion point.
      100.0,//X Coordinate of alignment point
      0.0,//Y Coordinate of alignment point
      0.0,//Z Coordinate of alignment point
      2.5,//Text height
      1.0,//Relative X scale factor.
      0,//0 = default, 2 = Backwards, 4 = Upside down
      0,//Horizontal justification 0 = Left (default), 1 = Center, 2 = Right,3 = Aligned, 4 = Middle, 5 = Fit
      0,//Vertical justification. 0 = Baseline (default), 1 = Bottom, 2 = Middle, 3= Top
      "some text",// Text string.
      "Standard",//Style (font).
      0),//Rotation angle of dimension text away from default orientation.
      DL_Attributes("mainlayer",256,-1,"BYLAYER"));
if DL_Codes::AC1009; all is alright, but not support Layers styles and other (AutoCad 11/12)
I use VS2008 with MFC librory
thanks in advance.
dxflib is great work, really nice code. Thanks the author!
Oleg
