How do I draw a curved line with an arrowhead at one end?
Postby bwallum » Sat Feb 19, 2011 9:52 pm
Hi
I want to draw a curved line with an arrowhead at one end to indicate the rotation of a disc. How do I do that please?
bwallum
Postby andrew » Sat Feb 19, 2011 10:28 pm
Curves (splines) cannot have an arrow at the end in QCAD. Please draw a short leader (see Dimension - Leader) at the end. Leaders can be so short that the leader itself is not visible, only the arrow.
Postby bwallum » Sat Feb 19, 2011 10:38 pm
andrew wrote:Curves (splines) cannot have an arrow at the end in QCAD. Please draw a short leader (see Dimension - Leader) at the end. Leaders can be so short that the leader itself is not visible, only the arrow.
Thanks Andrew. I think I may have found an alternative. Unicode characters 27F2 and 27F3 do the job for me (indicate clock/anticlock wise movement)
I can get the text edit box up in QCad, I can select the characters from Arrows Supplementary 1 and see them in the text editor. However they will not show on the drawing when I select the position. Where am I going wrong in this final step please?
I can get normal text to appear ok.
bwallum
Postby andrew » Sat Feb 19, 2011 10:45 pm
QCAD fonts only define a small subset of the 100000+ Unicode characters.
You can extend fonts as described here:
http://www.ribbonsoft.com/rsforum/viewtopic.php?t=1028
This will of course break compatibility of your drawings with other QCAD users. For arrows, using leaders would probably be the preferred way.
Postby bwallum » Sun Feb 20, 2011 9:23 pm
Thanks Andrew, I've now drawn an arc, added a leader (with a very short lead) and it does the job quite nicely. I've also made a block out of it for future use. Thank you for your advice.
Kind Regards
Bob
bwallum
