ttf2cxf
ttf2cxf
Postby mondalaci » Tue Jul 20, 2010 11:26 pm
Hi guys,
I'd like to use the ttf2cxf utility but I cannot find it anywhere. Please help me out!
Thanks,
Laci
mondalaci
Postby Lorenzo » Thu Jul 22, 2010 8:05 am
Please have a look here to download the source code and here for the usage.
Bye
Lorenzo
Postby mondalaci » Thu Jul 22, 2010 1:17 pm
I've already checked the download link that you offered and the FTP request takes forever and never completes.
mondalaci
Postby Lorenzo » Thu Jul 22, 2010 2:03 pm
mondalaci wrote:I've already checked the download link that you offered and the FTP request takes forever and never completes.
That link works for me, so your problem is not the link itself. Maybe something related to your Internet access?
Lorenzo
Postby mondalaci » Thu Jul 22, 2010 3:50 pm
You're absolutely right! It didn't work from Hungary but it did work from the UK. Does RibbonSoft block Hungary?
mondalaci
Postby mondalaci » Fri Jul 23, 2010 3:19 am
I could download the tarball but I got a library related error upon execution even if I install (the deprecated) libstdc++.so.5:
./ttf2cxf: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
The output of make neither looks encouraging:
g++ -o ttf2cxf -I/usr/include/freetype2 -lfreetype main.cpp
main.cpp: In function ‘int conicTo(FT_Vector*, FT_Vector*, void*)’:
main.cpp:92: error: ‘pow’ was not declared in this scope
main.cpp: In function ‘FT_Error convertGlyph(FT_ULong)’:
main.cpp:152: warning: format ‘%04X’ expects type ‘unsigned int’, but argument 3 has type ‘FT_ULong’
make: *** [all] Error 1
mondalaci
Previous Post
Postby rgenzer » Sun Apr 24, 2011 2:27 pm
This post:
http://www.ribbonsoft.com/rsforum/viewt ... hlight=cxf
Solved the same problem for me.
rgenzer
Re: Previous Post
Postby biggocharley » Sat May 14, 2011 7:23 pm
rgenzer wrote:This post:
I had posted this problem on linuxquestions.org <http://www.linuxquestions.org/questions/programming-9/compile-and-install-from-a-tarball-878364/>
I copied the arial.ttf font file to the same directory as the binary, ttf2cxf, which in my case is a folder /ttf2cxf/ttf2cxf-0.0.0.1-src
Since I have a 32 bit system it seems that the binary should work as is. After correcting a missing lib file, this is the result of trying to run the command
charley@mint-2 ~/ttf2cxf/ttf2cxf-0.0.0.1-src $ ./ttf2cxf arial.ttf arial.cxf
TTF file: arial.ttf
CXF file: arial.cxf
FT_New_Face: Unknown error
Segmentation fault
What is a "Segmentation fault"? Obviously I'm doing something wrong --any ideas what it is?
biggocharley
Postby biggocharley » Sat May 14, 2011 10:27 pm
Oops!! I had inadvertently put my ttf file into the wrong directory-- corrected this and the program works fine.
biggocharley
