How to repeat a block along lines and arcs?
Postby matbech » Sat May 14, 2011 10:25 am
How can I insert a block or just a line at a same distance along a path made of lines and arcs?
In this drawing:
there is a road, but how can I draw street-lamps with 20 meters of distance?
Thanks!!!!
matbech
Postby Lorenzo » Sat May 14, 2011 4:50 pm
You need to proceed for lines and arcs separately.
  • For lines: use move-copy command.
  • For arcs: you need to know the radius of the arc, then calculate the corresponding angle according to your distance (20 m). Say your radius is 40 m: the corresponding angle is
    distance/radius = 0.5 rad
    then use rotate command.
please remember that 1 rad = 57.3°.
Lorenzo
Postby matbech » Sun May 15, 2011 12:30 am
:D Thanks a lot!!
matbech
