Problems between demo & prof versions
Postby Cpat » Sat Aug 20, 2011 4:25 pm
I had a demo version, then bought the professional version. Now when I open the professional version and click on the search key in the help screen I get the message
'file:///Users/bm/Desktop/qcad-2.2.2.0-1-demo.macosx.tiger.universal/doc/chapter24.html#aligned dimension'
It apparently is looking for the demo version of a page.
How do I fix this.
Apparently you are not the only company that has problems installing software on a Mac. I've had more problems this month on Mac installations than I had in 25 years on Windows.
I think Steve Jobs should quit worrying about iPad and iPods and get rid of this 40 year old obsolete software he's using on the Mac. [/img]
Cpat
Postby andrew » Sat Aug 20, 2011 4:35 pm
The help tool unfortunately remembers the last used manual. To flush its memory, please delete its configuration file as described in our FAQs:
http://www.ribbonsoft.com/qcad_doc_faq.html#15
-> 15. I cannot access the manual in QCAD. It used to work in the demo version / a previous version.
Postby Cpat » Sat Aug 20, 2011 5:01 pm
I'm running Mac OS 10.4 which has a /Library/Preferences folder but do not see any file named "com.Qt Assistant.plist".
Cpat
Postby andrew » Wed Aug 24, 2011 3:25 pm
Sorry for the delay. I've been trying to get Tiger 10.4 up and running again but it's simply too old and won't install or run on any modern Mac computer anymore.
The file "com.Qt Assistant.plist" should be there, more likely under /Users/your name/Library/Preferences/
Postby Cpat » Wed Aug 24, 2011 4:41 pm
It is not in /Users/your name/Library/Preferences/ or any other folder.
Cpat
Return to Chat
