I could really use 0.01mm (for Ponoko) and 0.025mm (for Epilog Laser) line weights so I can design directly for laser cutting.
Please consider adding them explicitly or adding support for custom line weights at the Layer level.
Two years of running sed scripts from the command-line to fix SVG files every time I make a revision is getting a little tedious.
Thanks!
Andrew.
