When i make a text in a truetype font (Verdana for example) and than Select it and choose Modify, Explode the output looks good in QCad.
(example downloadable here: http://netcontrol.nl/qcad/welkom.dxf)
But when i import it in my favority CNC software (usbcnc, www.edingcnc.com) there's obviously something wrong here...
I just dived a bit deeper into this problem, and tested the same function in CamBam and that works great.
I just noticed that it seems something to do with the conversion of "spline" as the parts missing are all 'splines'
Am i doing something wrong or is this a bug ?
@Andrew: Great software, i'm absolutely buying a license from you. It's a very low learning curve for me. Keep going on this way!
