language menù - cannot change language
If you are having problems with QCAD 3.0, post here. Please report bugs here.
Postby enrifisa » Sat Dec 03, 2011 10:57 am
When I try to change language the program doesn't change language. It remains English although when I call the language menu it displays the name of the language chosen.
I found the in the program folder there are also italian files but in the menu I can't choose my language.
enrifisa
Postby andrew » Sat Dec 03, 2011 11:55 am
QCAD 3 only supports English at this point (see also file readme.txt or Help - Show Readme).
The QCAD 3 final release will support English, German, French, Italian and Spanish.
Postby hungerburg » Sat Dec 03, 2011 2:53 pm
andrew wrote:The QCAD 3 final release will support English, German, French, Italian and Spanish.
RC2 is partially localized; I did spot an error though: it is "schließen" instead of "schliessen", with a sharp-ß.
hungerburg
Postby andrew » Sat Dec 03, 2011 3:04 pm
hungerburg wrote:RC2 is partially localized; I did spot an error though: it is "schließen" instead of "schliessen", with a sharp-ß.
I've decided not to use ß for now as we don't use that character in Switzerland and I'm unfamiliar with the rules involved. Eventually, a proper de_DE localization might be provided, no promise for QCAD 3 though.
Postby Husky » Sat Dec 03, 2011 10:56 pm
andrew wrote:I'm unfamiliar with the rules involved
It's really complicated - but "Schließen" is correct!
Return to QCAD 3.0 Troubleshooting and Problems
