Filled triangle
Use this forum to ask questions about how to do things in QCAD 3.0.
Filled triangle
Postby andrew » Mon Dec 12, 2011 10:37 am
From a QCAD user:
If there is an easier way to create a filled triangle (rather than creating a leader dimension, exploding it, then deleting everything other than the solid triangle) please advise.
Postby andrew » Mon Dec 12, 2011 10:38 am
To create a filled triangle, please proceed as follows:
- Draw the triangle with lines
- Select all three lines
- Menu 'Draw' - 'Hatch'
- In the dialog choose 'Solid Fill' for 'Type' and click OK.
- You may want to delete the three lines. The solid fill can exist on its own.
To reuse the arrow, you might want to create a block and insert it with the appropriate rotation angle / scale every time you need an arrow.
Return to QCAD 3.0 'How Do I' Questions
