draftmode really works, but neither df nor draftmode appear in the manual
index.
Both should appear there.
I am sure there is a way to turn draftmode off on the command line, but
have had difficulty finding the way.
A hint in the draftmode discussion sec 11.3 would help. For example, one
could write:
"To determine if draftmode is on or off, simply look at (or create
if you do not have one)
a hatched area or large textbox and click the red underlined pencil
to see the display changes as you toggle drafmode."
The df command does not seem to immediately change the display,
so words about what is supposed to happen with this command (turning
draftmode on? off? somehow? ) would be helpful.
As would examples in the manual of commands that have the
precise effects.
Thanks for considering these suggestions.
