Installation Problem of QCad Ver 3.0.0 RC2
Use this forum to ask questions about how to do things in QCAD 3.0.
Postby vkadal » Wed Feb 01, 2012 10:21 am
Linux (see QCAD 3 Page for details)
(Installer)
Version: 3.0.0 RC2
I have downloaded the above version . After down load is completed I double clicked the bin file. Ubuntu 11.1 is not initializing the installation process.
I think it has to be installed through the terminal window. Kindly let me have the commands to install the same.
vkadal
Postby andrew » Wed Feb 01, 2012 12:04 pm
Linux browsers usually save any downloaded file as regular file (not executable). Please make the downloaded installer executable, then launch it.
The procedure to make a file executable depends on your Linux distribution, Window Manager and versions thereof but usually involve a right-click on the file, followed by choosing preferences or similar.
Postby vkadal » Wed Feb 01, 2012 3:16 pm
it has to be installed from the terminal by typing
change the directory where qcad has been downloaded. Then type
sudo apt-get install qcad
vkadal
Postby clive » Wed Feb 01, 2012 4:32 pm
vkadal wrote:it has to be installed from the terminal by typing
I have recently installed on Ubuntu, for me this worked.
For Ubuntu 11.10
1.Download bin file from the QCAD store (download area) -save for example to desktop.
2."Right-click" on file and set the permissions to allow executing the file as a program.
3.From the Terminal -type -Desktop/qcad-3.0.0-rc2-prof-linux.bin.
after running this.
4.You will need to install the 32bit libs - so again in the terminal, type
sudo apt-get install ia32-libs
clive
Postby andrew » Wed Feb 01, 2012 4:37 pm
Please note that this will install the (old) QCAD 2.0 Community Edition and not QCAD Professional you have purchased and downloaded from our store.
Postby clive » Wed Feb 01, 2012 6:41 pm
Yes -thanks Andrew for pointing that out, I didn`t make it clear that the bin file needs to be downloaded from the QCAD store. I have edited my last post to reflect your observation.
clive
Return to QCAD 3.0 'How Do I' Questions
