Comment changer proportions des lignes d'axes
Ce forum est pour les utilisateurs de langue française de QCAD.
This forum is for French speaking users of QCAD.
Moderators: andrew, J-J
Postby f6bqi » Sun Nov 04, 2007 6:06 pm
Je suis à la recherche d'infos pour changer les dimensions des lignes d'axes. En effet la valeur la plus petite est encore trop grande. Par avance merci
Michel
f6bqi
Postby michael » Sun Nov 04, 2007 7:39 pm
Try to use this:
Use "pr" and / or "at".
Use Layers http://ribbonsoft.com/qcad/manual_refer ... ter12.html
Basically, you change attributes of a layer. -> This will change all entities on this layer.
Change Dimensioning-Lines
1. Edit, Current Drawing Preferences...
2. Dimensions.
3. Setup the values.
See: http://ribbonsoft.com/qcad/manual_refer ... r32.html#4
michael
TKS for informations but:
Postby f6bqi » Mon Nov 05, 2007 9:00 pm
When i go to "attributes" (at) and "line type" and "select ""Dash small" line. This line is too big for my drawing (A4 sheet) .Is there the possibility to change this for a smaller one?
f6bqi
Re: TKS for informations but:
Postby michael » Mon Nov 05, 2007 10:13 pm
As far as I know right now, it is not possible to change the Linetype itself right now.
But you can use maybe an other linetype by itself. Just change the Layer. This will also change all objects on that layer.
I don't know if I understand your question right.
Please show me an example. Upload an example Screenshot.
Upload your example image for example here:
(Images will be removed automatically after 60 day, if they are not touched any more.)
http://www.directupload.com/index.html
And link it then to this forum.
f6bqi wrote:When i go to "attributes" (at) and "line type" and "select ""Dash small" line. This line is too big for my drawing (A4 sheet) .Is there the possibility to change this for a smaller one?
michael
Image envoyee
Postby f6bqi » Tue Nov 06, 2007 9:04 pm
j'ai envoyé l'image "bouchon.jpg" au lien indiqué.
Michel
f6bqi
Re: Image envoyee
Postby michael » Wed Nov 07, 2007 1:37 am
Ok, and what is the LINK? Url? So that I can access it and view it?
f6bqi wrote:j'ai envoyé l'image "bouchon.jpg" au lien indiqué.
Michel
michael
Return to Français
