Line thickness does not change
mmasroorali
Postby mmasroorali » Sat Mar 10, 2012 1:59 am
I know how to use different thickness for different layers. But in my case qcad does not respond to this change. As you can see in this image http://www.bilder-upload.eu/show.php?file=8bdadc-1331341089.png, I am using different color and line thickness (0.5 mm, 1.0 mm, 2.0 mm) for the three layers shown, but only colors are changing. Line thickness remains unchanged. The three entities have been drawn in different layers.
Any suggestion will be appreciated.
Re: Line thickness does not change
Postby Clive » Sat Mar 10, 2012 6:34 pm
mmasroorali wrote:I know how to use different thickness for different layers. But in my case qcad does not respond to this change. As you can see in this image http://www.bilder-upload.eu/show.php?file=8bdadc-1331341089.png, I am using different color and line thickness (0.5 mm, 1.0 mm, 2.0 mm) for the three layers shown, but only colors are changing. Line thickness remains unchanged. The three entities have been drawn in different layers.
mmasroorali
Not sure about CE version but with the pro versions -no problem!
mmasroorali
Postby mmasroorali » Sun Mar 11, 2012 1:05 am
Does that mean it has only to do with versions? Yes, I am using the CE version.
Postby Clive » Sun Mar 11, 2012 1:31 pm
mmasroorali wrote:Does that mean it has only to do with versions? Yes, I am using the CE version.
Maybe!
I don`t use the community version.
Return to “QCAD Community 'How Do I' Questions”
