Draw > Circle > Center, Point
Postby peasthope » Sun May 29, 2011 9:01 pm
In QCad Version 2.0.5.0-Free-1 [Community Edition] running in up-to-date Debian Squeeze, select Draw > Circle > Center, Point. The Center appears to be accepted. Then the command displayed is Radius. It should be Point. Why is "Radius" displayed when "Point" should be? If I attempt to snap to a point, no circle is drawn.
Is this a bug? Can a circle be specified by center and point? If so, how?
Thanks, ... Peter E.
[Edit by moderator: post moved to QCAD Community Edition Forum]
peasthope
Postby matbech » Wed Jun 01, 2011 10:20 am
I CAN snap to a point!
matbech
Re: Draw > Circle > Center, Point
Postby Cristoperobin » Tue May 08, 2012 6:18 am
Is there any shortcut key, for this options?
Cristoperobin
