Turn on front, side, elevation views
Use this forum to ask questions about how to do things in QCAD version 3.1/3.0
Postby dwight » Wed May 16, 2012 5:24 am
I see from some of the screen shots there is the ability to show front, side, elevation views. I do not see where to turn this on. Is this functionality actually available?
dwight
Re: Turn on front, side, elevation views
Postby andrew » Wed May 16, 2012 8:30 am
If you mean to display multiple views (viewports) of the same drawing, you can choose the desired layout in the application preferences:
Edit - Application Preferences - Layout - Viewport Settings
Postby dwight » Wed May 16, 2012 8:41 am
This just displays 3 views of the same drawing from the same perspective. I am looking to see 3 views a top view, front view, and side view of the object from 3 perspectives. e.g view from the top, view from the side, view from the front.
Dwight
dwight
Postby andrew » Wed May 16, 2012 8:54 am
There appears to be a misunderstanding here.
Top, side and front views which automatically display the appropriate perspective of a 3D model only make sense for 3D CAD applications or modellers.
QCAD is a 2D CAD system.
Postby dwight » Fri May 18, 2012 5:20 am
Can you please explain the screen shot on the home page of the www.qcad.org, as it shows a top view, a side view, and a cut out 3d view.
dwight
Postby andrew » Fri May 18, 2012 8:57 am
Sure: the top and side view were drafted as usual with the QCAD 2D tools. the '3D' view is an isometric projection which was created from the front and side view with the isometric projection tool of QCAD.
Postby dwight » Sun May 20, 2012 10:21 pm
Were the top and side views drawn independently of each other? That is if you need to adjust some of the side view, do you need to manually go and do the same adjustment on the top view, like you would if you drew this on a piece of paper?
dwight
Postby andrew » Mon May 21, 2012 8:22 am
Yes. This is how it is usually done with a 2D CAD system.
Return to QCAD 3.1/3.0 'How Do I' Questions
