How could i export dxf file to svg
Post here to ask questions about or get help with the scripting module of QCAD 2.1/2.2.
Postby chaudharyparesh » Mon May 21, 2012 2:28 pm
I am going use first time .
i want to export any dxf file export in svg using command line with out gui
Is it possible ?
Waiting for reply.
chaudharyparesh
Re: How could i export dxf file to svg
Postby andrew » Mon May 21, 2012 2:58 pm
QCAD 3 (currently release candidate 5) comes with a dwg2svg command line tool which converts DXF/DWG to SVG.
E.g.:
./dwg2svg.sh -o output.svg example.dxf
If you are on Windows, you can use the attached zipped batch file (save it into the QCAD installation directory, where qcad.exe is).
dwg2svg.zip
(269 Bytes) Downloaded 118 times
Return to QCAD 2.1/2.2 Developers
