qCAD 2.1.6.4 / Ubunu 7.1 - Locks up on start
Postby tj » Sat Mar 01, 2008 3:07 pm
I purchased pro, and initially downloaded 2.1.3.2 After experiencing problems with pdf crashing upon creation, it was suggested I use 2.1.6.4.
When I start qCAD, the opening screen comes up and the customary log messages appear:
QCad ready.
Creating new file . . .
Then, instead of the usual log messages, nothing happens. Locked up. Only recourse is to force a quit.
Any ideas/suggestions??
Thanks!
tj
Postby ttrw » Sat Mar 01, 2008 4:21 pm
Hi tj
Are you able to provide a crash log? As this would help Michael and Andrew debug the problem. :D
ttrw
Postby andrew » Sat Mar 01, 2008 7:07 pm
QCad has been tested under Ubuntu 7.10, so it should work just fine. One wild guess: maybe your configuration file is messed up. Please remove the file ~/.config/RibbonSoft/QCad.ini and then start QCad again.
Postby ttrw » Sat Mar 01, 2008 7:44 pm
Andrew, I presume that the ini file is the same as a preference file?
I trashed the existing preference file, but that had little difference.
I'll throw away the existing build and download/ reinstall it again.
ttrw
Postby tj » Sun Mar 02, 2008 12:36 am
andrew wrote:QCad has been tested under Ubuntu 7.10, so it should work just fine. One wild guess: maybe your configuration file is messed up. Please remove the file ~/.config/RibbonSoft/QCad.ini and then start QCad again.
Thank you for the quick response.
That was the problem. Works fine now.
tj
attention QCad on OS X users
Postby ttrw » Fri Apr 11, 2008 11:53 am
Yes, I should add that trashing the preferences (plist) file fixed my problems too!
(Still wanting and waiting for a fix for backspace delete though!! :evil: )
ttrw
