Additional Commands
Additional Commands
Postby isocam » Tue Mar 18, 2008 4:00 pm
Dear Sirs,
I am very pleased with qcad, but would like to see the following two mods on the next version.
Can you add the ability to create an 180 degree arc using two points on its diameter. This would work similar to creating a circle using 2 points.
Can you allow the user to customise the layout of the icons.
Is there any release date for the next version ?
Regards
IsoCAM
isocam
Postby ttrw » Wed Mar 19, 2008 1:33 am
I thought that you could already do this, using the "2 Point Circle" command or with the "Ellipse Arc" command?
If you create a circle using the 2 point circle command, take the scissors tool and cut at the two opposite points on the circle to create a 180 degree arc. Yes it's not perfect, but it works, and the nice thing about QCad is that it is really quick and fast to do.
BTW, You can already customise the icon layout by dragging and repositioning the icon windows.
ttrw
