Print problem with the 2.1.6.4 version
Postby david666 » Tue Apr 01, 2008 1:14 pm
I used a hp1220c printer with cups on slackware 12.0
I work with 2.1.3.2 version and print with it or the next version without problem.
When i try to print with the last version this plan or another
[img=http://img406.imageshack.us/img406/3792/scan10016ht9.th.jpg]
i had this
[img=http://img241.imageshack.us/img241/9338/scan10015ez5.th.jpg]
Any idea ?
david666
Postby andrew » Tue Apr 01, 2008 1:58 pm
This is most likely a problem with the Qt version used for that release in combination with your printer driver / printer.
If you could contact us by e-mail, I'd like to send you a link to a pre-release of QCad 2.2, compiled with Qt 4.3.4 to see if the problem persists.
Postby david666 » Tue Apr 01, 2008 2:33 pm
I send you my email by your website contact
Thanks for your quick reply
david666
Postby david666 » Tue Apr 01, 2008 2:59 pm
I try your 2.0.0 pre version , and all seems good for the printer
Many thanks
david666
Postby andrew » Tue Apr 01, 2008 3:11 pm
Great - thanks for letting me know. QCad 2.2 will be released in a few days.
Postby The Punisher » Wed Apr 09, 2008 10:05 am
Same printer here, HP1220C with Kubuntu 8.04.
I worked with V.2.1.3.2 without problems.
To see my printers on dialog i use the command: ln -sf /var/run/cups/printcap /etc/printcap.
After that, portrait and landscape printing were printed well.
On 2.1.6.4 my HP1220C stop to print in landscape mode.
My other Samsung Laser still print in landscape mode very well.
On HP1220C all my drawing are cutted on the right side; If I print A4 paper in landscape mode first 9cm are blank and next 21cm correctly printed in landscape mode with the drawing cutted on its right.
This is a scan of HP1220C A4 printed with 2.1.6.4
http://www.bilder-upload.eu/show.php?fi ... oNljkV.jpg
This is a scan of Samsung SCX-4521F A4 printed with 2.1.6.4
http://www.bilder-upload.eu/show.php?fi ... KHtLKb.jpg
I need my Hp1220C to print in A3 landscape.
Now I draw on 2.1.6.4 and print in 2.1.3.2; It's no good!
The Punisher
Postby The Punisher » Fri Apr 11, 2008 3:29 pm
Just tested the latest version 2.2.0.0
Printing problem solved.
Thanks Andrew for your effort.
The Punisher
Postby ttrw » Fri Apr 11, 2008 7:58 pm
andrew wrote:Great - thanks for letting me know. QCad 2.2 will be released in a few days.
Like usual, I can't find it anywhere! :?
Andrew, can you PM the link please?
ttrw
