Grid and Dimension relationship
Posted: Tue Aug 11, 2009 11:24 am
I'm running 2.2.1.0 on both windows XP and vista. I imported a png image [which already has its own unit of measurements] as a layer. I need to make an overlay with additional drawings. How can I make the dimension tool to match the units of measurement in the png image. I tried to change the Application preference grid setting and that made qcad go nuts. It generates a QCad.ini file in ..\Application Data\RibbonSoft which causes qcad to hang. This file must be removed before qcad can start operating. Is there a better way? Thanks.
