Batch export to PDF from GUI
dmitpon
Post by dmitpon » Wed Apr 07, 2021 8:14 am
Hi there! I wrote a small script. Batch export to multi-page PDF from GUI. It exports the visible (unfrozen) layout blocks in the same order as in the block list widget. I hope it will be useful to someone. I am a beginner in Javascript. The script probably contains bugs. I only tested in win 10.
Batch2Pdf.zip
(33.84 KiB) Downloaded 1611 times
Re: Batch export to PDF from GUI
Post by andrew » Wed Apr 07, 2021 10:08 am
Thank you for your contribution!
Can you please clarify if this can be included in the next QCAD release? If so, please indicate under what name we can list you under Help > About > Credits (this can be a real name or a nick name such as "dmitpon". We'd put this under Misc > Import/Export.
dmitpon
Post by dmitpon » Wed Apr 07, 2021 10:14 am
Hello, Andrew! I agree to include this script in the next QCAD release. My real name is Dmitry Ponomarev.
Post by andrew » Wed Apr 07, 2021 10:25 am
Excellent, thanks!
I've added this to the repository at:
https://github.com/qcad/qcad/tree/maste ... /Batch2Pdf
dmitpon
Post by dmitpon » Wed Apr 07, 2021 10:47 am
Ok, I'm glad my script was useful.
