set current linetype-lineweight scripts - How to update Pen Toolbar?
dfriasb
Senior Member
Post by dfriasb » Sat Mar 28, 2020 8:40 am
Hi all,
I've written some scripts to set current linetype and lineweight with command line and keyboard input. They are working exactly as I wanted, but Pen Toolbar is not updated when script runs. This is a little bit confusing for me. Can I introduce some function in script to update Pen Toolbar? Any help will be very welcomed.
Best regards,
lineweight1.js
script that sets current lineweight to 0.13mm
(1.15 KiB) Downloaded 600 times
linetype2.js
script that sets current linetype to id 2
(1.25 KiB) Downloaded 616 times
[email protected] | davidfriasarquitecto.es
Re: set current linetype-lineweight scripts - How to update Pen Toolbar?
Post by CVH » Sat Mar 28, 2020 1:18 pm
A source of info might be:
PenToolBar.js
Post by CVH » Sat Mar 28, 2020 1:45 pm
What I read there is:
The startup values are gathered as: colorCombo.setColor(di.getCurrentColor());
di is the document interface.
On a value change it is stored as:
EAction.getDocumentInterface().setCurrentColor(color);
The diff with yours is that you change the document pen.
PenToolBar.js alters the document interface pen....
