Modify text's X scale property
wdfortee
Post by wdfortee » Sun Aug 09, 2020 9:12 pm
I'm using QCAD Pro 3.21.3 on Windows 10 x64.
I'm trying to modify a text entities X scale but it seems I have no idea what I'm doing wrong.
I've created a text entity using:
text = new RTextEntity(document, new RTextData( [text values here]);
Looking at the reference material, doesn't look like there's a way to modify X scale in RTextData, so I was trying different variants of
text.setProperty("PropertyXScale", "1.0");
and:
text.setProperty(new RPropertyTypeId("PropertyXScale"), "1.0");
Using script debugging, the first results is
Error: :-1:-1: Wrong number/types of arguments for RTextBasedEntity.setProperty(). <native>('PropertyXScale', 0.5) at -1
and the second doesn't crash, but doesn't modify X scale.
Any help is appreciated.
Re: Modify text's X scale property
Post by CVH » Mon Aug 10, 2020 1:16 am
If there is a 'Properties' way I don't know.
And indeed, no examples of the use off XScale.
I would look for Set & Get functions in the Class list:
https://qcad.org/doc/qcad/3.0/developer/annotated.html
Those looks to be implemented by RTextBasedData.
RTextData inherited those.
And I come to:
    var document = this.getDocument();
    var di = this.getDocumentInterface();
    var op = new RAddObjectsOperation(false);
    var textPos = new RVector(23,16);
    var textData = new RTextData(
                textPos,            // position
                textPos,            // alignment point
                0.35,               // height
                1.0,                // text width (ignored for now)
                RS.VAlignTop,       // alignments
                RS.HAlignLeft,
                RS.LeftToRight,
                RS.Exact,
                1.0,                // line spacing factor
                "MyText",           // the text
                "Courier",          // font
                false,              // bold
                false,              // italic
                0.0,                // angle
                false               // simple text without formatting
    // Set XScale:
    textData.setXScale(0.88);
    var text = new RTextEntity(document, textData);
    op.addObject(text);
    di.applyOperation(op);
:P
wdfortee
Post by wdfortee » Mon Aug 10, 2020 1:32 am
Worked perfectly, thanks so much. I guess I need to spend more time looking at reference.
In the past, I've only coded python scripts and simple programs from various languages. The API for QCAD is a little overwhelming for me and not exactly sure how to always track down the getters and setters.
Thanks again. This probably won't be the last post.
