Are these features available?
Saddabadhad
Post by Saddabadhad » Fri May 29, 2015 5:35 am
Hi
Can I load an aerial photo jpeg file into QCAD as a background and then draw lines on it and print both out?
Also can I do vehicle swept path analysis such as using Turn.lsp http://hawsedc.com/gnu/turn.php ?
Re: Are these features available?
Post by andrew » Fri May 29, 2015 8:19 am
Saddabadhad wrote:Can I load an aerial photo jpeg file into QCAD as a background and then draw lines on it and print both out?
Yes. You can insert images using Draw > Image.
No, QCAD does not have any kind of Lisp support. The script interface available in QCAD is ECMAScript (JavaScript) based.
