Drawing clock wheels and Escapements
chriscam
Post by chriscam » Thu Oct 22, 2020 12:26 pm
I note it is stated that QCAD has no special design facility to draw clock wheels. There are other packages and the best todate I have found that will generate a cycloidal wheel is the Delph Electronics package. My question is whereas that package will generate the wheel can I import that wheel drawing and then add to it a deadbeat escapement or a recoil anchor?
Chris
Re: Drawing clock wheels and Escapements
Post by CVH » Thu Oct 22, 2020 2:17 pm
No, but such things can be implemented by a script type library item.
If your good at math ... InvoluteSpur.js is an example file.
Yes, once all is merely a drawing one can copy/paste everything.
Don't count on us to invent the escapement.
Don't expect that QCAD will make it move. :wink:
