DWG Support in Trial Pro Edition?
- Registered Member
I just downloaded the Trial version of Pro and tried to open a DWG file. I received an error stating the ....x.dwg import failed. Tried opening a few different DWG files that were created in AutoCAD 2020. Do I need a non-trial version to open DWG files? Thanks.
Re: DWG Support in Trial Pro Edition?
Not that I am aware of.Penelope58 wrote: ↑Tue Dec 24, 2024 10:11 amThis is a common concern, as some trial versions have limitations on certain features, including DWG file support.
QCAD trial is a fully functional Pro version with limitations on session time and number of sessions.
Then there is also no reason to compare QCAD trial with trials of other applications.
