Intersecting Lines
tchiz
Intersecting Lines
Post by tchiz » Wed Jun 18, 2008 5:24 am
How do I draw intersecting lines that are not supposed to touch each other? As in a wire diagram, where two wires cross, but are not supposed to touch each other.
Post by andrew » Wed Jun 18, 2008 9:57 am
Is this a question about dxflib or QCad?
tchiz
Intersecting Lines
Post by tchiz » Wed Jun 18, 2008 10:36 pm
It is about QCAD
Re: Intersecting Lines
Post by andrew » Wed Jun 18, 2008 11:00 pm
tchiz wrote:It is about QCAD
OK - please post your question again in one of the QCad forums if you don't mind. This is a dxflib forum.
You can find the overview over the forums here:
http://www.ribbonsoft.com/rsforum/
Return to “dxflib 'How Do I' Questions”
