how do create a link with an external image
AndyB78
Post by AndyB78 » Mon Dec 06, 2010 1:52 pm
I tried to use the method "writeImageDef" but when I opened the dxf file with autocad the following error appears: "Unknown object type IMAGEDEF ignored".
Which are the correct step to do add a background image in a dxf file?
Thanks in advanced for your help.
Post by andrew » Mon Dec 06, 2010 10:01 pm
- Write the image definitions inside the OBJECTS section of the DXF file (see DL_Dxf::writeObjects / writeObjectsEnd).
- Write the image itself (writeImage) inside the ENTITIES section
Dagata-mining
Re: how do create a link with an external image
Post by Dagata-mining » Sun Apr 03, 2022 2:21 am
Any updates on that?? Been strugling for a bit and tried this approach without any succesz
Return to “dxflib 'How Do I' Questions”
