moving from 32 bit to 64 bit on FreeBSD
Locked
emm
Post by emm » Sat Jul 07, 2012 6:34 pm
I'm using QCAD2 quite a while now and after moving from FreeBSD-i386 to FreeBSD-amd64 there are some libraries missing in the 32 bit version (libXi and some more).
I'd strongly suggest making a 64 bit compilation of the pro version. The community edition does compile and run on FBSD-amd64 very well.
Maybe ths would better be posted to the suggestion list of the upcoming version 3 ...
Thanks for attention!
Re: moving from 32 bit to 64 bit on FreeBSD
Post by Clive » Sun Jul 08, 2012 10:16 am
Hi emm and welcome.
Your request has been added here also:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=636
You can use the bug tracker also for adding feature requests, you will need to register to use it.
Locked
Return to “QCAD 2.1/2.2 Suggestions and Feedback”
