Block references in a particular layer [Solved]
arun
Post by arun » Tue Jun 06, 2023 12:12 pm
How do I get the all the Block References from a particular layer.
I tried the
doc.queryLayerBlockEntities(layerId)
with the following code and I got an error message. Any pointer on the correct usage of this command
var doc = getDocument();
var layerName = getText();
var layerId = doc.getLayerId(layerName)
var blockEntities = doc.queryLayerBlockEntities(layerId)
Thanks,
Arun
Re: Block references in a particular layer
Post by andrew » Tue Jun 06, 2023 12:34 pm
queryLayerBlockEntities returns all entities that are member of a given layer and of a given block (i.e. are part of that block definition).
You could get all entity IDs on a given layer with:
var entityIds = doc.queryLayerEntities(layerId);
And all block reference IDs with:
var blockReferenceIds = doc.queryAllBlockReferences();
Then intersect the two (sorted) arrays:
entityIds.sort();
blockReferenceIds.sort();
var blockReferenceOnLayerIds = Array.intersect(entityIds, blockReferenceIds);
arun
Post by arun » Tue Jun 06, 2023 12:46 pm
Thanks Andrew. This is good :) .
Re: Block references in a particular layer [Solved]
Post by CVH » Tue Jun 06, 2023 4:19 pm
arun,
Remark that queryLayerBlockEntities() requires 2 parameters:
https://qcad.org/doc/qcad/3.0/developer ... 66b85e5e31
