Any method to know the authoring CAD software [SOLVED]
arun
Post by arun » Tue Jun 27, 2023 8:27 am
I have been wondering if there is any method in QCAD to check on the authoring CAD software that a particular drawing (.dwg file) is done through QCAD script?
I am using QCAD 3.28.1 on linux
Thanks,
Arun
Re: Any method to know the authoring CAD software
Post by andrew » Tue Jun 27, 2023 8:37 am
No. But you could mark documents that are created with your script with a document variable. For example:
document.setVariable("MyScript/Version", "1.0.0");
This is stored in DXF/DWG as XData.
arun
Post by arun » Tue Jun 27, 2023 8:58 am
Got it Andrew.
I was curious to find out the detail of the .dwg files that I receive :wink:
